Blocking windows
BnCKelley
Good afternoon everyone, I am trying to flock together three casement windows with a transom. My first ordeal is I can't blend the transom into the Windows like I thought it should do and this may not workout like I'm thinking but I'm also trying to block the four windows together and it won't do it because of an overlap and a spacing issue. Anyone have any clues to what I'm doing wrong?
See if this tech article helps:
https://www.chiefarchitect.com/support/article/KB-00525/creating-a-mulled-door-and-window-unit.html
If not, then you will probably want to post a simple plan that demonstrates the problem you are having.  Someone on this forum would then be able to quickly determine what you are doing that is preventing the windows from being mulled.
If all else fails, then you might want to contact our technical support team during normal business hours.
