BethVanDeusen Posted October 22, 2020 Share Posted October 22, 2020 Is there a way to put a pet door in a door? Link to comment Share on other sites More sharing options...
BethVanDeusen Posted October 22, 2020 Author Share Posted October 22, 2020 I want it to look like this: Link to comment Share on other sites More sharing options...
ericepv Posted October 22, 2020 Share Posted October 22, 2020 There are several Pet Doors in the Bonus Catalogs. Look for Accessories No.05 Pets. Link to comment Share on other sites More sharing options...
BethVanDeusen Posted October 22, 2020 Author Share Posted October 22, 2020 It seems the pet doors in the catalog are designed to go in a wall. Is there a way to insert a pet door into a door? Link to comment Share on other sites More sharing options...
ericepv Posted October 22, 2020 Share Posted October 22, 2020 Install the Pet Door on the wall next to the door, open the DBX and adjust the size then copy and paste to your door (I found this works best in an elevation view). Also, be sure to adjust the size of the casing and uncheck 'Use Sill/Threshold' (Casing tab). Link to comment Share on other sites More sharing options...
BethVanDeusen Posted October 22, 2020 Author Share Posted October 22, 2020 Thank you ericepv! Link to comment Share on other sites More sharing options...
ericepv Posted October 22, 2020 Share Posted October 22, 2020 I take that worked for you. Link to comment Share on other sites More sharing options...
lbuttery Posted October 24, 2020 Share Posted October 24, 2020 Beth: for real life use install the pet door as close to the bottom of the door as you can my golden ret. has a broken hip and he struggles with "tripping" on the bottom edge I had to buy the extra large door - normally for St. Bernards etc so he wouldn't have to stoop plus he is obese from lack of exercise I've been using petdoors for decades - I recommend the double flap doors for cold weather situations or high winds sometimes I built an enclave entrance and had two doors at right angles to prevent cold winds from entering house but the double flap doors work fairly well I spent less than this vendor so shop around - I believe I got mine from Home Depot this is just an example of the double flap door https://www.amazon.com/dp/B01LZ6NOHZ/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B01LZ6NOHZ&pd_rd_w=XET6g&pf_rd_p=f0355a48-7e73-489a-9590-564e12837b93&pd_rd_wg=gOssu&pf_rd_r=RH0F85V7C76T3YWSQX30&pd_rd_r=398e2b06-6e14-43c0-956c-a1a81f8bee7b&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYRzhMOTg2MldMTjEmZW5jcnlwdGVkSWQ9QTA2ODM5MTgyS1M3WEZLMzZUTURXJmVuY3J5cHRlZEFkSWQ9QTA5NTAyMzYxTVo5Sk9WMEtUU0Q1JndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Lew Link to comment Share on other sites More sharing options...
7DLN3QHXL4G9679C Posted December 14, 2020 Share Posted December 14, 2020 I've followed these steps and still get this issue. Any other suggestions? Can you explode a door or alter doors in any way other than dimension and material? #1917-Jamieson-Dog door issue-121420sh.pdf #1917-Jamieson-dog door issues-121420sh - Copy2.pdf Link to comment Share on other sites More sharing options...
nthnlwilbourn Posted March 23, 2021 Share Posted March 23, 2021 On 10/25/2020 at 12:58 AM, lbuttery said: Beth: for real life use install the pet door as close to the bottom of the door as you can my golden ret. has a broken hip and he struggles with "tripping" on the bottom edge I had to buy the extra large door - normally for St. Bernards etc so he wouldn't have to stoop plus he is obese from lack of exercise I've been using petdoors for decades - I recommend the double flap doors for cold weather situations or high winds sometimes I built an enclave entrance and had two doors at right angles to prevent cold winds from entering house but the double flap doors work fairly well I spent less than this vendor so shop around - I believe I got mine from Home Depot this is just an example of the double flap door https://www.amazon.com/dp/B01LZ6NOHZ/ref=sspa_dk_detail_2?psc=1&pd_rd_i=B01LZ6NOHZ&pd_rd_w=XET6g&pf_rd_p=f0355a48-7e73-489a-9590-564e12837b93&pd_rd_wg=gOssu&pf_rd_r=RH0F85V7C76T3YWSQX30&pd_rd_r=398e2b06-6e14-43c0- https://www.worktime.com/employee-monitoring 956ca1a81f8bee7b&spLa=ZW5jcnlwdGVkUXVhbGlmaWVyPUFYRzhMOTg2MldMTjEmZW5jcnlwdGVkSWQ9QTA2ODM5MTgyS1M3WEZLMzZUTURXJmVuY3J5cHRlZEFkSWQ9QTA5NTAyMzYxTVo5Sk9WMEtUU0Q1JndpZGdldE5hbWU9c3BfZGV0YWlsX3RoZW1hdGljJmFjdGlvbj1jbGlja1JlZGlyZWN0JmRvTm90TG9nQ2xpY2s9dHJ1ZQ== Lew oh I'm sorry to hear this about your dog, I hope he gets better! Do you know if there is a similar double-leaf door in the bonus catalog? Link to comment Share on other sites More sharing options...
lbuttery Posted March 23, 2021 Share Posted March 23, 2021 Do you know if there is a similar double-leaf door in the bonus catalog? Hi: no idea ? probably not, but doubt if you need it for the plans ? Ky did fine until Nov 2020 then he weakened and maybe stroke and was euthanized Dec 5 Lew 1 Link to comment Share on other sites More sharing options...
nthnlwilbourn Posted March 25, 2021 Share Posted March 25, 2021 On 3/23/2021 at 8:03 PM, lbuttery said: Do you know if there is a similar double-leaf door in the bonus catalog? Hi: no idea ? probably not, but doubt if you need it for the plans ? Ky did fine until Nov 2020 then he weakened and maybe stroke and was euthanized Dec 5 Lew oh god I'm so sorry to hear that, excuse me! condolences on your loss, but now he's in a better place! Link to comment Share on other sites More sharing options...
lbuttery Posted March 26, 2021 Share Posted March 26, 2021 its ok, Ky had a happy 9 yrs even with his disabilities he enjoyed life as best he could Lew Link to comment Share on other sites More sharing options...
