Wall End Issue/No drywall
cajunland
Issue in X12 when using break tool to adjust wall for an extension over a column.
Bare wall end fir stud and overhead framing stud can be seen in wall section instead of drywall.
See attached file/pic.
I do not believe soffit is viable solution as I am seeing that soffits will not frame.
So framing is important.
Many thanks to Solver as he addressed this issue and resolved it for my needs by applying different wall types to the wall area drawing. I posted my original files as reference and Solver's solution file (1868954996_MHD_sampletemplateplanSolutionWallEnds).
And the solution frames out too as can be seen in file with camera Perspective Floor & Perspective Framing views.
Wall End Issues.plan
1868954996_MHD_sampletemplateplanSolutionWallEnds.plan
