Exposed Stud
cbdesign
  • 2 weeks later...
I have same issue in X12 when using break tool to adjust wall for an extension over a column.
I was not able to view Solvers response.
See attached file/pic.
(PS) I do not believe soffit is viable solution as I am seeing that soffits will not frame.
So framing is important.
Wall End Issues.plan
*Had trouble uploading file. But it was just simple test .plan
Thanks.
Ah!
Looks so simple now.
I believe I see differences in walls (pony/divider+default wall type ) to make the solution.
And looks like they both frame out as needed even better than one wall broken up.
I will make separate thread and reference your solution.
FYI: I will also post thread for a second floor dormer walls soon.
Beaucoup Thanks.
