Add Custom Notes - Library
ChiefuserMathews
12 hours ago, ChiefuserMathews said:
I found a way. I had to "make cad block" then add to library
And, when you want to re-use it, you'll be placing a CAD block, not a text object, and it will be on the default cad layer. If / when you explode it, it will revert back to its original layer and you can also then edit the text if needed.
