Brick Ledge wall type not showing
stevenyhof
I have a pony wall type with a 12" dropped brick ledge. This is used often in our foundation design to line up the main floor walls.
After setting up the main floor and generating the foundation, I used my brick ledge wall type to replace the area in the circle - which works great on the level 0 floor, but does not show up on the elevation - like I didn't even add it.
Would anyone like to look and see if you can figure this out? I had it working several days ago when I made it.
Here is a previous post
Thank you
SND_D_Residential Template.plan
