angusc
How do i duplicate a room?
Working on an iPad with the mobile version, how do I duplicate or copy/paste an existing room or an existing object?
thanks,
Angus
What is the mobile version?
There is no "Mobile Version" I think he means Chief Architect that he uses on an I Pad.
to copy an object you select the object and then from the "Edit Toolbar" (the one that only appears when you select it), select the copy command and then "Paste it" in another plan or location.
An entire room would be done by "Shift-marquee-select or Edit - Edit Area" commands and then again "Copy - Paste" into another plan or location to address your original question.
    28448
    Burtonmadness
    Burtonmadness
