Default Drywall Color
Thad58
15 hours ago, Thad58 said:
But you cant grab a library color for the drywall. OK so Chief just responded and said that was a difficult task. I will let you know. I set up a meeting
For colors Chief doesn't let you apply easily like this you can just use the BM RGB numbers ( or Hex on Mac too) from their Website
( or any manufacturer eg SW instead) and put them into the Color Box manually
 or even color pick them from a wall you already changed manually to the desired color within Chief.
Then save it to your Library for later use....
This is a website that has this info too .....they are selling paint but the info needed is there too....https://encycolorpedia.com/e7e5e0
