Plan File
TotalStation
Hello,
          I have been working on a plan file for awhile now and suddenly it takes forever to change doors,trim or any other task that i want to do," Its Slow". i thought it would be my system i am using but i changed to other plan files of the same size that i am working on and its speed is just fine, May i have done something in this plan files settings? Any advice??
CA X12
If it happened suddenly, what were you doing just before it happened ?
It is not necessarily the size of the file that dictates the efficiency that it runs.  Content is critical.  Do you have imported cad or imported symbols ?  Did you build a custom item ?   What is the "system" you are using ?  Upload the plan file if you want to know if it is slow on a different system.  Is it slow in 3D or in plan view ?
