Extracting handrail profiles
Chrisdutch89
6 minutes ago, Chrisdutch89 said:
My client has asked that a specific handrail profile be placed on the drawings
A detail drawing and specification or used in the model, for visuals? It's just a square...seems all you need to know is the dimension? There's lots of squares available for moldings, just type 'square' in the library browser and filter by type to moldings. Once you've made your selection, you can rename and resize.
You need to right click on the library item and "Place Molding Profile".  You can do this in a CAD Detail Window.
What's happening in your example pdf is that you are placing a molding line with that molding.  Display it in a 3D view and you will see that you have a square molding polyline with that molding.
  • Upvote 2
