Deleting cabinet side plus its door frame/bar in an open cabinet
RaquelPorlamar
Hi everyone,
I am using CA Interiors X9, and I wa nt to recreate this corner open shelf without having the highlighted divider as you can see in my CA. Any tips? I tried two separate cabinets deleting sides but it doesn't eliminate the side cabinet door frame.
Thank you in advance ❤
Two ways using two cabinets, make sure that auto fillers are off. Just saw you are on X9, sorry plan is in X12- attached it anyway-maybe get a trial or download the X12 viewer. One is two angle front cabinets, the other is two standard that overlap. If you need it really clean then do what Eric said and build it from parts or create a symbol.
I don't remember if you can have 0" separations in x9-they are used to do what I posted.
