solver Posted April 28, 2020 Share Posted April 28, 2020 Watch on YouTube: http://youtu.be/dDT6wbrrVRM?hd=1 3 2 Link to comment Share on other sites More sharing options...
Kbird1 Posted April 29, 2020 Share Posted April 29, 2020 Thanks Eric..... I normally use + before each word to get everything or click the "and" Option as you showed once it finishes it's initial search if there are too many results. M. Link to comment Share on other sites More sharing options...
DzinEye Posted April 29, 2020 Share Posted April 29, 2020 5 hours ago, solver said: Watch on YouTube: http://youtu.be/dDT6wbrrVRM?hd=1 Outstanding Eric... thank you so much for putting that together. I had no idea about the 'all activity' area and the deeper level of search detail available. Link to comment Share on other sites More sharing options...
ACADuser Posted April 30, 2020 Share Posted April 30, 2020 Odd but my screen says "Unread Content" On some forums, you can also search the user ID, like "Jamb Switch" and the user name is a separate field. Link to comment Share on other sites More sharing options...
Dezigner99 Posted May 5, 2020 Share Posted May 5, 2020 Eric, Thank you! This helps a lot. I was actually searching by typing "_______ AND _____". No wonder everything result had "and" in it. (Headslap!) Link to comment Share on other sites More sharing options...
lori-esd Posted April 6, 2021 Share Posted April 6, 2021 Helpful! Altho when I put in Move+Cabinet+filler....I got nothing. Link to comment Share on other sites More sharing options...
