Edit/update CAT5/TV symbol
BryanXG
Thank you for the guidance.
As a note for others that may follow; when editing the block, be sure to change the layer and group properties as needed.
Even though the initial block was electrical, the new block becomes default (which is not electrical), so the layer and symbol color is not correct.
The is more Tips like this in the Knowledgebase ( KB)  or FAQ Library too.....
https://www.chiefarchitect.com/support/article/KB-00805/editing-2d-cad-blocks-assigned-to-3d-symbols.html
