Dimensions not locating objects
DesignerPro2020
9 minutes ago, DesignerPro2020 said:
Any suggestions on forcing dimensions to snap to framing objects?
Here are the critical settings in the dimension default being used for that. You can locate other objects as well if need be.
image.thumb.png.378f284eade214935c8f5add6d9c794c.pngimage.thumb.png.97100d18e748a3d1f9dde643663f9d06.png
