MichaelaS
LAYOUT SET - PAGE SIZE ISSUES
I've created my layout templates, according to their sizes. Within the template everything looks great - everything fits within the sheet margins, the page size aligns with what I've titled each template to be, etc. However, when I go to send my drawing to my prefered layout the 'Drawing Sheet Setup' drawing sheet size is a different size. So when I change the setup sheet size to what I want then my entire layout is far too large and I need to scale everything back down. (the blue outline in the image below is my page outline 18x24)
@MichaelaS I have some possible solutions but it would all just be guesses, please post your .plan and .layout file so we can take a quick look
@michaelas Wherever you save your working files you can simply load those up here the way you loaded the dwg's. If need be chief architect has the ability to zip your .plan file with the Backup Entire Plan tool located under your file menu with the .plan file open in CA.
If It is more than 25 MB when zipped you can share a link to your cloud account here.
9 minutes ago, MichaelaS said:
Anytime I try it says that the upload has failed.
Also be sure the plan or layout files are not open in Chief when uploading.  If you need to go the cloud account route you might as well do the file backup from layout and then you can include the .plan and .layout files together in the same zip file.
From your original screen shot it seems to be ok, other than your margins are not set correctly, seen by the blue line, and your plan view is a little small for the paper size you have selected.  Maybe a few more details of what you are scaling down would help.
Start a new plan using the same template. Draw 4 walls and send that to layout.
If you have the same problem, save that new plan, close Chief and upload it and the .layout file.
It looks to me like all your setup was just accidentally done with the wrong page size in layout.  You'll likely just need to adjust you title block and various page info. using Transform /Replicate or similar.
Making some assumptions here ...but if you have made a Template for each different size ie 11x17, 12x24, 24x36. 30x42 etc ????  then switching the Drawing Sheet Setup size does not automatically switch the Layout File used to the correctly sized one you made ......When you send to layout it simply opens the Layout specified in your Preferences under General>New Plans .
Currently that appears to be a 46 x 61" page size in your Image above?  ( I've never encounter that size personally ) and the Print Margins look all wrong ,especially the Top and Bottom Settings of 705mm and 940 mm , that is  27 3/4" and 37" respectively or nearly 65" ? which seems wrong to me.....
    27611
    ChiefAKBuilder
    ChiefAKBuilder
  • Similar Content
    • By nancyscial
      Hi
      I am using x10.  I have a kitchen type that I will multiply many times and save by unit #. I need to have the unit # show up on my layout page for each plan that is saved.
      Not sure how to save the units and have the info show up.
      Thanks in advance!
    • By WAShideler
      I am hoping someone can tell me how to handle this.  I have done all the framing, and using the project browser, sent all the Wall Details to a Layout page.  When I first did this, everything showed up perfect...The wall detail names on the walls in plan view, corresponding to the labels in the Layout.
      Well, I made a couple of window changes, rebuilt floors and ceilings and now what I have is this: The wall detail numbers show up correctly in the plan view, but the layout shows: "Wall Layer 4 Viewed from outside".  I must be able to change the Views on the Layout to correspond with the plan view!
      HELP!!!!
      TIA
      Bill
      Funky Labels.pdf
      Plan View.pdf
    • By robdyck
      Does anyone have some decent ideas to keep track of details? I'm working on a large home that has over 40 details. If I decide that a particular detail, let's say it's #5, is redundant or not required, that means I've got 35 details and their callouts to renumber?????
      I've been calling out details from the cross sections in layout, specifically so I don't have to open each section view (which is so tedious) in order to place callouts. But there's no schedule tool in layout to make any sort of auto-numbering system. And no linking system from the callout to the detail camera (I like to keep them live) or to the CAD detail (which I use for less dynamic details).
      This is as bad or worse than the issues one runs into when using room numbers.
      Surely there is some system within Chief for actual architectural plans?
    • By Ridge_Runner
      I have struggled with this problem for some time. When I send views to Layout, I will sometimes have a difficult time "picking" a line to edit (see attached view). By hit-and-miss I am able to select it off to the left from where it shows in the view. I could never determine why or what causes it to happen until today. I have sent countless views back to layout just so I could edit them - sometimes! By chance, I discovered today, while working on a cabinet sheet of views, the problem started again. I re-sent a view, could edit the lines in place by picking them where they showed in the view. After some edits, I could not select the lines as before; they had to be selected to the left of shown. I did a mental backtrack of what I had done just before this occurred. The only thing I had done different between the functioning view and the non-functioning view was to move the view label. I like to move the labels close to the view they tag to prevent possible errors in labeling. Sure enough, if I moved the label I could no longer pick a line as normal. If I didn't move the label, I could pick the lines as normal. Would someone please try this on one of your layout sheets to see if this happens on your system? I don't think it would be a setting but I don't have a clue why it would happen. BTW, I mostly move my labels to the left if that has any bearing.
      Thanks, Mike
    • By CUJojo
      I am curious as to what folks are doing with their typical detail drawings.
      Do you save them within the project's plans?
      Do you same them within the project's layout?
      Are they on their own file?
      What are the advantages and disadvantages of each method....
