Use a "Note Schedule" in lieu of a "Room Schedule"
Joe_Carrick
Rooms don't have an "Object Information Panel (OIP)" so it's not possible to add "Custom Fields" to be used in the "Room Finish Schedule".
Notes OTOH do have the OIP and a Note placed within a Room will pick up the "room" attributes, allowing all that data to be retrieved in user macros and displayed in a "Note Schedule" substituted as a "Finish Schedule".  This makes it possible to use the Notes as "Room Labels" with both numbers and names as well as including Custom Columns in the Schedule.
It may take a bit of work to define your new "Finish Schedule" with the appropriate "Custom Fields" and the "User Macros" but in the long run you will have a much more comprehensive Schedule.
  • Upvote 3
