solver
Order of Edit Toolbar / Context Menu Items
This is the right click (context menu) that shows when a Tray Ceiling is selected.
Is there some order to this list? For example Explode Tray Ceiling and Make Nested Tray Ceiling are not together, the list is not alphabetical.
Some similar tools are grouped together, some seem random.
The order of this particular list is designed to be as similar as possible to the order used by other kinds of objects. For instance, "Explode Trey Ceiling" is in the same position as other "Explode Object" commands (i.e. "Explode Dormer"), and the "Make Nested Trey Ceiling" command is in a similar position to the "Make Trey Ceiling from Room" command.
I've always wished we could change and lock the order, it just doesn't seem logical 1/2 the time, same for the Main Edit Toolbar, which I mostly use instead now....
    28422
    SpacemakerHE
    SpacemakerHE
