Wall outline not showing in Wall Elevation
DavidAllgyer
1 hour ago, DavidAllgyer said:
I can't seem to figure out how to get the wall outline to show up in my Wall Elevation views. This worked fine in x10, but hasn't worked in X11. Any thoughts?
Probably best if you upload the plan file.  I don’t have this issue.  Also can you please update your signature with not just the software but also hardware info.  Many times the answer is dependent on what version and is sometimes tied to a hardware issue such as drivers out of date for you GPU as just example.
