How to import room names into plan?
dskogg
48 minutes ago, dskogg said:
I have a plan that I am working on and i have somehow erased the added room types before i started plan...so now i dont have my standard room names.
Does an archive copy still have them ?
I am still not clear on how you erased Room Names?  are you talking about just the room label text? Room Types or ?
4 minutes ago, glennw said:
File>Import>Import Default Settings>choose a plan>Room Types
Thanks Glen, that worked...it helps if i ask the right thing...
How are you with all the fires?  I hope you and your family are ok.
David,
We are well away from the fires, but are affected by smoke and ash - visibility is very low some days.
Over 1000 houses burnt and many people perished in the fires - not a good situation, but has probably got a bit better in the last few days due to cooler weather.
33 minutes ago, glennw said:
David,
It has been reported that the main cause of the fires was people setting them, the drought just set the stage. Can you confirm those reports, I wonder?
David,
I don't know if the main cause was arson, but last I heard there were 28 people arrested or charged with lighting fires.
One case was a guy who started a backburn to protect his dope crop!
A lot were started by lightening strikes.
Certainly the drought has contributed to the ferocity of the fires.
