Window Trim Apron Settings?
ShowmeCHIEF
47 minutes ago, ShowmeCHIEF said:
apron size
CA uses the Casing size currently I believe though a suggestion has been made to allow us more control.
I use a Sill Molding with apron built in if I need something different.
22 minutes ago, solver said:
Yep , it was that thread where I started using a symbol  , it is posted over there a few posts below this one
https://chieftalk.chiefarchitect.com/topic/23244-q-window-how-to-do-a-sheetrock-return/?do=findComment&comment=192925
I have not found a reason yet to use it on the exterior.
