Thick Wall Lines
BenjaminZ
I am trying to find out how to fix the walls in this plan.  This was probably created in an older version of Chief, but I am using the current X11.  The lines are so heavy that I can not differentiate between the drywall and the stud.  This particular plan is the only one that I have come across that has this issue and I am trying to see what I can do to remedy it.  It doesn't seem to matter if I change the thickness under the wall definition or not.  I am thinking whoever worked here before did something to it and I have no idea how to undo it.  Any help is greatly appreciated.
Thank you,
Ben Zent
Thick Walls.zip
