Raposo
Chief Architect to Revit
Hi,
I am looking for someone to model, in Revit 2019, a project that is already done in a Chief Architect, .plan file.
I'm asking for the .rvt file. The modeling has to in metric units and there is no need to make sheets or render.
It is a project of a single family house, 2 floors and 200 square meters of area.
I believe you have to re-draw it, chief has no conversion to Revit.
On 1/6/2020 at 2:24 PM, Raposo said:
Hi,
If you want me to model the home in Revit for you, I can. I have both Chief Architect and Revit, so I should be the best help available to you. Please message me to discuss more information.
    27499
    Bren0625
    Bren0625
  • Similar Content
    • By KTKArch
      So I just returned from a demonstration of current high tech and its use in the future of home design.
      I must say, Point Clouds from laser scans are the way to go.
      Sure the high end is 1/4 million $ scanners and drones/aircraft. But even a $75K backpack scanner at the right resolution will take a 6-hour site measure and office drafting time down to a 30-minute walkthrough/around and 1 - 2 hours in the office for 3D overlay.
      Can't put out $75K...hire it out and markup 3rd party's price for the walkthrough. You not only get the building but the topography as well. Fences, trees, and neighboring buildings will get picked up. Great for landscaping and the all-important tree schedule. You will be able to simply measure tree trunks at whatever height the local jurisdiction requires from the comfort of your desk.
      If you find any boundary markers. Put a recognizable 3D item over them to locate them in the point cloud. Want to verify the scale of the point cloud? Measure one or more items that you can verify later and scale as needed. Better resolutions reduce and eliminate this but dramatically increase your file size.
      So a good scan will be within a 1/2" of accuracy and you know those pesky double-thick interior walls you can't get to? Or that one that goes off at an angle or stairs that follow a curving wall. No guessing the radius or if there are multiple slopes on the roof. Its all in the point cloud at less than half the time and cost of hand measuring.
      Still can't 'see' it? Watch when the countertop installer measures up the next kitchen with one. The countertop fits like a glove after a simple scan is fed into the CNC machine. If the countertop installer can make it work we can too.
      So Chief Architect, when are you going to simplify importing point clouds into CA?
    • By JanHalter
      Hi there!  I have been searching for a bit, and attempted a few things to no avail.  Anyone have a step by step tutorial (or is it just not possible?) on how to at the very least import an existing title block from Revit or CAD to Chief?  I am far from proficient in Chief at this point and wondering if it's possible.   We want to make sure the title block matches our Revit sheets exactly...in case we have to draw something in one program vs. another in the same CD set.
      I tried exporting to .dwf from Revit and importing into the layout page, however it doesn't allow me to import that file type into the main layout page.
      Also, am I blind? I can't figure out where to put my signature...so I just typed info below.
      Janea
      Rafter P Construction
      Cheif ArchitectX10
    • By nVisionTEKBIM
      Hi everyone! I'm new to ChiefTalk, and just joined because I want to put my foot in the door to possibly move away from Revit to CA in the future. I'd like those that have (or have had) expert level experience with Revit to compare using Revit to Chief Architect for mainly residential projects.
      I am a Revit expert with previous commercial experience for previous employers, but my preference and bread-and-butter is high-end residential. I have a business that offers BIM services (renderings, 3D modeling, drafting, ect.) and have current clients that I need to use Revit with. Revit is very powerful, but it is obvious that it's geared more towards commercial rather than residential. I have spent hours and hours creating and continuously modifying my families (i.e. doors, windows, vanities, ect.). Plus, everything takes way too long! CA seems to have all the beautiful content already available, and the videos make it seem so easy to place and modify.
      A couple of my clients may be able to be convinced that CA is better. They are builders that view the model for constructability and want the documentation to be superb, as well as have weekly client meetings that I attend in which I have to to tweaks per client requests (which is so difficult with Revit!). I am very good at creating detailed plans and 3D modeling, with many compliments.
      So, if you have or previous had expert Revit experience, please tell me your thoughts of CA if you switched or use both. I'm really curious! I have very very limited time, so I'd only want to try the trial if it's worth my time. Also, since you can't save in the trial, I feel if I liked it a bit I would end up renting the software to practice more. Too bad the student version is not available to anyone like Autodesk does.
    • By Haskellf
      In South Florida, homes are prominently constructed out of concrete blocks, metal studs & beams, concrete headers/lentils/beams, and wooden trusses. Which software would you recommend that would be best suited for concrete home construction?
      Also, I can't find any training videos for CA that uses concrete blocks and therefore I wanted to ask you all if you know of any videos or tutorials for CA... Or maybe one of the aforementioned software would be better suited for concrete block construction?
    • By Reddrick
      Everyone what do you think of Revit, Sketchup, and Autocad? And how do you think they compare to Chief Architect for traditional conceptual home design, custom complicated modern home design, and detailed construction home drawings?
