Scissor Truss roof still shows conventional vault
DanatCV
I created scissor trusses in several areas of my design.  They all show up just fine in the framing view.  But in a 3D perspective, the vaulted ceiling still displays as a conventionally framed roof (ceiling pitch is the same as the roof pitch). I'm a relatively new user so I'm probably missing something.
HD Pro 2020
Build: 21.3.1.1x64
Intel Core i5-6300 cpu @ 2.40 GHz 2.50 GHz
RAM: 8.00 GB
Thanks for your reply!  The ceiling planes matched the roof pitch when I created the trusses.  So I assume I must first create ceiling planes that are the proper pitch to match the bottom chords of the intended scissor trusses before creating the scissor trusses.  Thanks again!
50 minutes ago, DanatCV said:
HD Pro 2020
Build: 21.3.1.1x64
RAM: 8.00 GB
You can put this in your Forum Signature , so you don't need to post it each time ...
https://chieftalk.chiefarchitect.com/topic/18908-signature-here-at-chief-talk/?tab=comments#comment-155662
some answers are version specific and also in that vain the HD Line has their own Forum over here  too:
https://hometalk.chiefarchitect.com/
