custom light symbol
madcowscarnival
Is there a way to simply tell Chief Architect a pline (2'x4' rectangle) that it should be recognized as an electrical lighting object so that it will connect electrical runs?  I need to demonstrate a basic lighting plan in a large open barn where they will be using 2'x4' hanging high-bay LED's.  I did find the "short double recessed tube lighting" that will work for the symbol, and can edit that object, but might want to create a 12" diameter high-output LED basic symbol too.
To clarify my question.  Is it possible to draw a basic shape, perform a special conversion, and assign it as an electrical object?
1 minute ago, madcowscarnival said:
Chopsaw, thank you.  I was looking for the convert to symbol button, but it was not available until I converted my basic cad to a plinesolid, then to symbol.  Excellent, I appreciate it.
Yes it will need to be a 3D item.
