Adding a text box to the user library
Doug_N
Is there a way to make a text box (just text) a library item?
for example:
This design uses
OBC Part 11
Egress Option A
Imagine the attribute has a box around the text so that it is a stamp.  I would like to add the box to the drawing and then change the option.
Joe!
You are the man!!!   Yes, that works perfectly.  All this time I have been drawing a polyline rectange around the text to add it to the library.  Now I realize it wasn't the box that let me add the text it was the marque select that was allowing it!  Sometimes I miss the most obvious things.
Thanks
