TINY Numbers on Plot Plan
WAShideler
I am trying to figure out where I need to go to INCREASE the size of plot plan numbers and compass headings.
HELP!
I really need for the County to be able to read the numbers tomorrow morning when I meet with the Plans Examiners!
TIA
Bill Shideler
I think there is a default Plot Plan Text Style that you can use or edit to your liking depending on the scale of the plot plan.
Open ALDO ( Active Layer Display Options ) and make sure Layer Properties are turned on.  Select a plot line of the plan and it will show you what layer it is on and what Text Style it is using.  Look for Plot Plan Text Style or hit the define button to make your own.  You will likely need a text height of 30" or more.
