Ruby Macros
lavorhaynie
16 minutes ago, Doug_N said:
Where would you put parentheses in this?
owner.internal_area*0.025.round(2)
I think Michael was trying to give you a hint...... , you need to round the result of the multiplication (of the Room area) so bracket that 1st
(owner.internal_area*0.0250).round(2)
15 minutes ago, Doug_N said:
Arrgg, why doesn't this work in the callout?
as CS mentioned it looks like you have assigned the wrong macro name to the Label it is not called 025roomarea but roomArea025
 ...... is it set to evaluate correctly?
You have to specify the room as the thing you want to get the internal_area of.
Try this macro:
# Macro Name: "room_internal_area"
# Displays the internal area of the room a Note is in.
# Copywrite by Joseph P. Carrick, August 2, 2019
referenced ? obj= referenced : obj=owner
begin
  obj.room.internal_area.round(2)
rescue
  "object isn't a Room"
end
begin
rescue
end
Joe, Wow, works like a charm!  Thanks Joe.
I added a bit of simple code to get the percentages and just put the macro in a text box.  One macro to get the area, and one to get the result.
