print showing wall color grey
DianeP
Thanks for trying to help.  I wasn't clear.  The color is viewable on the layout page but it won't print with the shading that is there on the floor plan view.  It just gives the wall lines with out the shading.  Sometimes I want it  to have the shading showing when it is printed.
try color off is grayscale in preferences, then print in color with you print drivers. If you turn off color using the color off button you will see what it looks like. Just make sure yuou keep colors on the dark side so they show up   . light gray doesn't work.
 Perfect!   Just what I wanted and couldn't remember how to do.  Thanks!!!!
