Pass through on off-angle corner
ckirste
This is probably one of the funkiest tub-showers I've seen. This is from a 1982 remodel - you can tell right! It's a whirlpool too.
Trying to model this with Railings and pass through's overlapping at the corners.
It looks pretty good, but the frame disappears at the corners. When I pull them apart, the wall shows up. I can't find the perfect overlap point.
Suggestions? Should I just create a polyline moulding on top and bottom to cover the gap?
