Creating A Flat Ceiling Under A Deck Roof
akabuilder
I have a split level entry deck with a gable roof extending over it. The roof is larger  (wider and deeper) than the deck itself and I can't get the roof to create a flat ceiling instead of just following the gable underneath. Suggestions? Any changes I have tried only generate a ceiling over the deck itself and the siding next to the house disappears
Hancock House Plan.plan
2 hours ago, solver said:
I moved the roof planes to the 2nd floor and created an Open Below room under them to create the ceiling.
That works,  but suppose you did want a landing showing at the second floor?
The solution would be to put the open to below room on the 27th floor (exaggerated to make a point) with it's roof and adjust the height of the floor accordingly.
picture shows blue house on level 1
purple on level 2
oragnae on live 3
green on level 4
and red on level 5
solution similar to eric's
179703157_ScreenShot2019-07-13at9_03_56AM.thumb.png.10a1f1099f91c99ce27c723de72e201b.png
