Locations for fixtures on a cathedral ceiling - Sanity Check
Ravenquills
Hello All:
I am designing a house with all cathedral ceilings on the second floor. The idea is to have all the duct work etc exposed. In some areas I would like to do some sloped soffits for light fixtures. So the question is and it may be stupid is do i place everything on the attic level so that it is on the ceiling?
Thanks
best
a
1 hour ago, Ravenquills said:
best
a
Keep them on the second floor, you can adjust offsets in the fixture's open-object dbx. You can also edit offset in 2d sections or 3d space. The delete surface tool an d convert to symbol tools can help you if you have a fixture with a base built for a flat ceiling.
Thank you!
