Client Information
builtright3
For some reason the client information has a space in between the address and phone number. I never had an issue with this until X11 that I know of.
Anyone know what's happening here or experience the same problem?
Thanks in advance
I will call Tech support if no one can help me.
3 minutes ago, Chopsaw said:
The unused city, state, and zip macro's are causing the space.
Im not having the problem on a new layout. Only my layout that I have been using for several years. I rebuilt all the macros and otherwise doing the same thing as far as I can tell
If you are always going to enter the city,state,and zip code in the Street field of the Client info, then you don't need the city, state, and zip macro's in the label.
One is my layout and one is a new layout from CA. Bothe entered exactly the same and I cut and paste the macros into a rich text box for both.
2.thumb.PNG.6f568c8a8daa0474babeacfe06f63018.PNGCapture.thumb.PNG.2a90cd3284bc505301e8610caa5e0a59.PNG
Single line spacing is set
Edited by builtright3
Clarification
Go to Tools>Project Information>Client Information, and make sure that you don't have a carriage return after the Street text (or any of the other entry boxes).
I can duplicate your problem by placing a carriage return after the zip code in the Street text.
5 minutes ago, glennw said:
Go to Tools>Project Information>Client Information, and make sure that you don't have a carriage return after the Street text.
That does not actually do it for me Glenn.  It must be something similar to that in the text box.
I went to the bottom of the street name text box and back spaced to the text and that did the trick.
Thank You!!!:rolleyes:
You would think that you would have to have a character in the text box with spacing in between. That's really strange to me. I mean the text didn't even show a space or separation anywhere.
Also I was able to duplicate the problem as you did
Clarification
