Layout Box Not Stretching
skoz44
Hi,
I've just started using X11 (from X7) and am having issues when sending items to layout.  When I tell it to "Send to Layout" with "No Scale" selected, I'm then not able to stretch the view larger or smaller with the corners any longer.  When I stretch the corner, it simply moves the line like a polyline.  Any suggestions
Here are a few options to try
Marque select the layout box or CTRL select and use the little control tab at the top.
Or hold down the X key and drag a corner.
Drag a side and position with point to point tool.
Rotate/Resize about current point works like the software did back in X9 if you hold down the X key it will resize proportionally about the anchor point.
