Patio surface / wall issues
jjifmeyer
What would be the best and easiest way to go about building a retaining wall for the pictured area.
I have tried both"retaining walls and terrain walls" but get unwanted results.
Plan is loaded up above in the topic stream.
19 minutes ago, HumbleChief said:
I think it might be bad forum form to not follow up on your first
Yes you are right.
First of all thanks for the help earlier adding, a thin surface to to patio concrete worked great.
18 minutes ago, HumbleChief said:
Hope this helps...
I appreciate all the help!
But i am trying to make the retaining wall follow the curvature of the back side of the patio.
Something like this:
but as you see it gets funky.
Thanks
It's doable, painful using Chief's curved retaining wall (really, really awkward) tools, but doable. Same thing as above make sure the walls and regions don't overlap and sit adjacent to each other the proper distance. BOTH walls and regions are curved!!
4 minutes ago, HumbleChief said:
Too easy - here's a hint attached.
What tool are you using to make the curved region?
I cant seem to locate.
Also do you now the difference between porchs and patios in CA.
And why they act different?
The 3 key will create a break in any line or p-solid like a region. Press the 3 key, click the break point where you want it. Now right click the new line segment and change to curve. VERY basic stuff.
...and yes there's a difference but I honestly don't know. Try googling for the answer?
Here's a vid.
Thanks Im getting close, I did watch a video and figured out the curved terrain.
Thanks for all your help.
No info on the patio and porch, I did google.
Anyway that is what was screwing with the wall earlier (disappearing)
Once I changed it from patio to porch the wall would not disappear
thanks again.
Also I think the etched line on the Retaing wall is the footer of the wall.
thanks again.
4 hours ago, glennw said:
I don't think Chief has a default Patio room type.
There is a "Patio" Room type in CA but I cant find any info on it.
In reality the area I'm working on would actually define as a "patio"
but need to change it to porch to get it to work properly.
Not sure why.
I will continue my search on more info about this.
Thanks
"Patio" it is a custom room type that someone has created.
It's function has been defined as a "Slab" room.
Maybe that is why you can't find any information on that room type?
These are the OOB room types.
16 hours ago, HumbleChief said:
Thanks for the help.
It was truly a pain but I think I have it worked out.
Although not as perfect as I would like.
I would think there would be an easier way to control those cured retain walls.
