how to fix wall half interior and half exterior
jpdesign
7 minutes ago, Chopsaw said:
"Lower Wall Type if Split by Butting Roof".
That should do the Trick....
If the garage roof plane is Manual pull it back off the house wall too and then let it "re-snap" to the house....
26 minutes ago, Chopsaw said:
Try in Wall specifications Roof > "Lower Wall Type if Split by Butting Roof".   If not post your plan file for professional help.
Hello Chopsaw,
Thank you so much to point this option out.
I didn't know what the option "split by butting roof" for. Now I understand.
Appreciate your help.
Josh
