Room Perimeter Macro
Fotis1960
Does any one have a macro for Room Perimeter? I'm not a professional CA user. I use it for small home projects and for fun so I haven't learned how to create my own macros yet. Any assistance would be appreciated.
Thank you
Thank you
What Info are you looking for?  as CA has built in Marcos for the basics like Area and Perimeter etc
I wanted a fast way to get the total feet of base molding needed for a room. I realized that I could get it from the materials list after I posted the question but would still like to have a room perimeter macro. I couldn't find one for perimeter in the CA provided ones.
- If you click on the Room, you can make a Room Polyline (edit toolbar) and it has a total length etc in the DBX.....
- you can also Place a Room Finish Schedule in a CAD Detail (best) and use the available Columns to document thinks like Moldings.
The room object has the following properties (attributes ). So technically if you want to get the perimeter, see the example, make sure evaluate is checked ...
"Perimeter: " + owner.perimeter.round(0).to_s
I am not an architect and this is my hobby.
BT
ObjectId: NVPublisher
ceiling_elevation................................. 201.125
ceiling_finish_layers.......... [NVPublisher, NVPublisher]
ceiling_finish_name.......................... Color - Bone
ceiling_insulation............................ NVPublisher
ceiling_platform_layers..................... [NVPublisher]
ceiling_thermal_envelope_area............. 390.89083774113
conditioned.......................................... true
conditioned_is_set_to_use_default_value.............. true
custom_pattern_scale.................................. 1.0
dimensions................................ 18'-3" x 21'-6"
drawing_group.......................................... 35
fill_color_from_background.......................... false
fill_color_from_layer................................ true
fill_line_weight........................................ 1
finished_ceiling_elevation........................ 200.625
finished_floor_elevation............................ 92.75
floor_elevation...................................... 92.0
floor_finish_layers......................... [NVPublisher]
floor_finish_name........................... Secret Garden
floor_insulation.............................. NVPublisher
floor_number............................................ 2
floor_platform_layers.......... [NVPublisher, NVPublisher]
floor_thermal_envelope_area........................... 0.0
function.......................................... Bedroom
has_ceiling.......................................... true
has_floor............................................ true
has_floor_supplied_by_room_below.................... false
has_monolithic_slab................................. false
has_roof............................................. true
has_shelf_ceiling................................... false
include_in_living_area............................... true
include_in_living_area_is_set_to_use_default_value... true
include_in_schedule.................................. true
internal_area....................................... 391.0
layer............................................... rooms
layer_is_default..................................... true
layer_line_color............................... 2151678207
layer_line_style........................................ 0
layer_line_weight...................................... 18
layer_set..................................... Default Set
layer_text_style....................... Default Text Style
moldings.................................... [NVPublisher]
name.......................................... MASTER BDRM
pattern_angle......................................... 0.0
pattern_horizontal_spacing............................ 8.0
pattern_vertical_spacing.............................. 8.0
perimeter............................... 952.2245367022674
schedule_number....................................... R29
show_room_label...................................... true
simple_schedule_number................................. 29
standard_area....................................... 416.0
stem_wall_height........................ 47.99999999999999
stem_wall_top_elevation.............................. 92.0
transparent_pattern................................. false
type_name..................................... Master Bdrm
use_type_for_name................................... false
volume................................... 3679.56623286403
wall_coverings......................................... [NVPublisher]
14 hours ago, solver said:
If you make a Room Molding Polyline that takes over the default base molding, you can assign macros to its label.
Here I'm showing Visible Length and Perimeter.
Note how Perimeter minus the width of the door equals Visible Length.
How did you get the Visible Length?
3 hours ago, Kbird1 said:
It's one of the pre-made Macros you can insert into the Label under Object Specific.
Thanks. I don't know how I missed that. I also tried typing it in but forgot to add the _ . I'm learning.
Note, if you want to actually perform calculations using those values - you need to have a custom evaluated macro.  example:
Macro Named "MyCustomMacro" or whatever and your object's visible_length = 498 inches
  • obj = owner
  • x = obj.visible_length/12
  • x = x.to_s + " ft."
The result would be 41.5 ft.
That last line make x a string instead of a floating point number.  The key here is that Chief's built-in macros display a value but you can't use it for anything else.  By creating a macro that accesses the underlying attribute you the capability to manipulate the data and use it for more complex labeling.
  • obj = owner
Thanks for the Tips Joe , I was able to make it work , but also rounded it up (.ceil) so it didn't show 9 decimal places ! , so here it is if someone else wants to try it....
Perimeter-Baseboard_add to Room Molding Polyline label.json
On 3/27/2019 at 7:53 PM, Joe_Carrick said:
Hi Mick,
Another possibility is to use  .round(3) to get just 3 decimal places max.
Thanks Joe, I do appreciate you posting these Macro Tips for those of us who aren't Macro Gurus....
Because it was For Moldings in this case I wanted to round up to the Next Ft , and actually added 1 ft extra too , to make sure I allow for some Waste , 1-2ft extra per Room is nothing really , couple of length per house as I see it , but the Marco is pretty easy to change to Suit each person's needs, or just round it like you suggested, or even to .round(0) and just add your own 10% (?) waste at Final Takeoff instead.
On 3/27/2019 at 8:20 PM, Kbird1 said:
...or just round it like you suggested, or even to .round(0) and just add your own 10% (?) waste at Final Takeoff instead.
Or just skip the polyline steps and automate the whole thing using the actual molding information provided by the room...
Molding test.plan
Simply drop a copy of the text box into any room you wish to get the molding quantities for that room...and this is just a pretty quick and simple example of the type of information we can automatically pull from the actual model now.
Molding test.plan
Hey thanks Michael, that works nicely , but I have to say, I think you are probably one of nine guys on this forum who could write that Macro...and understand how it works :)
I made it into a Library "Block" with the Label for Others to use, you just have to remember to "explode" the Block after you insert it , so the macro "reads" the Room it is in , and not just show the Data from the Room I made the Block in. (see pic below)
Macro :   AlaskanSon_Room Moldings.json
CAD Block : MHD_Room Molding CAD Block.calibz
59 minutes ago, Joe_Carrick said:
Mick,
If you make it a "Note" instead and save that to the Library you can skip the Block.  Just put the macro in the "Text above the Line" field of the Note
Thanks Joe , I had forgotten that we can now add Notes to the Library , so will give that a try too.....
*** there is too much text for the "Text Above Line", for the Callout, so it's better to put the macro in the Text of the Note and have it report in the Schedule, which maybe better anyway as it keeps the drawing "cleaner".
