wpdesigninc
Oddly, unable to modify item sizes all of the sudden from the Open Oject function
Is it possible some setting was changed on my program? All of a sudden, I am unable to modify the dimension of an object, such a cabinet height or railing height when I open an object. I am able to make a modification when I do so from an elevation view manually. This just started happening today. I shut the program down and restarted with no success. Wondering if I accidentally turned something off or locked a setting in place for this result. Please advise.
Post a simple file that demonstrates the problem.
And please fill out your signature so we know what software (at a minimum) you are using.
See this thread for a how to:
2 hours ago, wpdesigninc said:
Thank you for the comment. After shutting things down a second time, it resolved itself. Weird!
There was a Video Driver Issue a While back that caused access to some TABs in the DBXs not to accessible , not sure if it is related or even what Videocard you use since your Sig. isn't done.
M
    27478
    Oilersfan20
    Oilersfan20
