• ×   Pasted as rich text.   Paste as plain text instead
      Only 75 emoji are allowed.
  • Member Statistics
    27610
    Total Members
    6254
    Most Online
    ajworkman93
    Newest Member
    ajworkman93
    Joined
  • Similar Content
    • By howardmccall
      A serious error occured (exception thrown) Contact technical support.
      While removing some interior walls this message occured.  I can't get rid of it and now I can't even go into other parts of the home and change anything without this stopping me.  If you can help please tell me what to do I have another 6 hours I need to work today.  Hoping for the best
      scan0289.pdf
    • By Doug_N
      I have a strange problem with floor joists on this project.  Once again a client-supplied file that I have made lots of adjustments to, but when I generate floor joists each room on the second floor generates a rim joist around it, and the joists go all over the place.
      Here is a view of the first floor prior to generating joists.
      And here is the view of automatically generated joists
      Note the seemingly random direction of joists in closets and in some floor panels.  Why is the program generating floor joists around each second floor room?
      Floor_Framing_Problem.zip
    • By stanlee92218
      I have all of my exterior walls laid out and I have been following along with the video to learn the software, I am new to this! I went to change it to perspective floor overview and I keep getting this error message.
    • By decorators3
      Hi
      I've been away for several months and only now getting back into my CA 11.  But when I open my plan I get this error message.  I've tried updating my library but I have NOTHING no core no bonus no manufacturers.
      Can anyone direct me or do I contact tech support
      Thanks
    • By GCCISarah
      Hi everyone-
      In the last several plans I have created in chief X11, using a Camera View with a Reference Display of the As-Built, I have the As-Built Reference Display file set to render as a Glass House view. The Glass House referenced model displays, but without any of the dark outlines to show the features of the model. I have included an image of a remodel I am working on currently, where the referenced As-Built shows as a faint blue shape. Nothing like the examples Chief gives of a reference display, below.
      Any thoughts on what setting I might be able to change to get the 'outlines' back. I have also included an example image from Chief I found online, which has the desired 'outlines' in black.
      This does ONLY happen when I'm using Glass House View as a *Reference Display* in the plan I'm working on. If I were working on a plan and change the rendering technique to Glass House, the outlines are visible. This only happens in Reference Display.
