neo-angle wall connections
FrozeDesignBuild
Hello,
We need help with making neo-angle walls.  Please look at our glass shower enclosure.  Where the walls meet, we get bad connections and have not been able to "join" them.  What causes this?  Is there a way to change Wall or Door settings to prevent this from happening?  Thanks for your help, Susan.
2019-03-04_Poll_-_Master_Bath_-_proposed_bath__1.plan
On 3/8/2019 at 12:03 PM, FrozeDesignBuild said:
Eric -
Thanks for the link to prior forum.  I will check out.  I had searched, but could not find anything.  So thanks.
-Susan
The Plan View does look horrible, some of the 3 Walls are reversed ie exterior wall side is in on some and out on others with different materials , plus the is Polyline Solids at the party too...... if you assign the 3x6 tile to the walls as a material and to a Wall Cap , the polyline Solids are not needed.
Ithe the walls set as railinging you shower glass is only 40" high   , uncheck that box if glass is going to the Ceiling or set the appropriate height eg 84"
still some wall issues though but i haven't got more time right now to figure it out....
