Cannot remove room divider
EconBlueprints
It disappeared as if by magic when I connected the interior room to an exterior wall.  The interior room was the stairwell I was working around and I did not realize Chief placed the room divider automatically, which it appears it does so the room is connected and does not try to make the walls exterior walls.
Thanks!
Lane
I recommend that you do not turn off the Connect Island Rooms option. Turning this off will mean that you will have to manually connect all of your island rooms.  If you forget, then a number of things in the program may not work correctly.  You will likely have problems with room related information including floors, ceilings, moldings, and other structural issues.
If you don't like where the program has automatically added the room divider, then add your own room divider and then delete the one the program put in for you.  If you don't want to see them, then turn off the layer.
