How to fix wall connections in off-angle corner walls to enable resizing the door
ChiefUserJarmo
Here's the issue I have - I have this weird corner case of walls with multiple angles. As shown in the image, the underlying CAD has a door and I just cannot resize the exterior door properly. I think it is because the walls on left and right just kind of run into the diagonal wall and block the resizing of the door. I tried editing wall intersections but that did not help. The side walls just snap back. Any ideas how to solve the issue? Right now CA allows me add a door with 339mm width, but I need 700mm width.
4 hours ago, solver said:
Try drawing Room Divider walls where the red lines are.
Finally got it working (in a way) with room dividers and changing the wall thickness. Not 100% accurate - but good enough.
Thanks again Eric, for pointing to right direction!
695727698_Screenshot2019-03-07at22_11_09.thumb.png.0974d897fe682af28c92e8ae6c0e37ce.png
