Sub Basement - Building Out A Submerged Padio
eraser82
I am trying to figure out the right order to building a padio with retaining walls and above ground railings.
In have my terrain set to automatic elevation and my ground floor set to -38". Not sure if that was the proper way to set up. Perhaps this is the source of my problems?
Thanks for any help!
Do you mean "Patio" ( I never heard of a padio as a name for a space)? Be that is it may, if you need to remove the terrain that is covering your "padio" you can use a terrain feature set as a "hole" to remove the unwanted terrain.
Otherwise I agree with Lew that more data is needed as to what, exactly your problem is please.
