Window/Door Casing at Pony Walls
nVisionTEKBIM
Hi everyone, I'm a new CA user here learning the software.
Does anyone know how to exclude the exterior window/door casing at the lower stone veneer pony wall? I can't find anything in any of the tutorials or on here.
I'd like the casing to stop at the stone water table, and have the stone veneer stop at the window jamb, and there be a stone window sill. I assume this is a simple fix that I just can't figure out.
    30404
    willmick
    willmick
  • Similar Content
    • By Nate_M
      Hello,
      I am working on an as built for a 1800's house. The door and window trim is 5 3/4" wide. My problem is that there a few instances where the door or window trim has been cut down to fit up against another wall. For example there's a window in one of the corners that is nearly up against the perpendicular wall. The trim on the left side of the window is 5 3/4" but the trim on the right side is around 3".
      Is there a way to place the window further into the corner and cut off the trim? Can I make the trim on only side of the window a smaller width? This is a pretty common occurrence in our work and I would like to have a method of solving this issue.
      Thanks in advance for any help you can offer.
    • By Trawen
      Hi,
      I was trying out Chief Architect X12 and wanted to do a corner window, but as you can see on the pictures, sash does not go all the way in the corner, but rather than that is cut off before it.
      Does anyone have any suggestion how to solve this?
      Thank you in advance.
      (on the last picture there is also added a post, but that does not affect bug at all)
    • By ChiefuserMathews
      Is there a macro ruby command that I can add to my window schedule to calculate the glazing area of a window
    • By SNestor
      What causes Chief to reduce the width of a mulled door unit?
      The images below show the before and after of mulling a door unit. The sidelights are "fixed door" units. Not sure that matters...but as you can see after mulling takes place the casing does not reach the baseboard.
    • By Aamir77
      Hi folks,
      I want to create a corner window with two different profile windows where height is different on both faces of windows like the one circled RED in this picture.
      I tried but failed to remove the corner post if I change the height of one side like this
      Need your guidance. I am using x10.
      Thanks in advance.
