Time to Show YOUR GOODIES!
Adrean
My latest Project, a 26,000 SF home to be built in Pflugerville, Texas:
https://skfb.ly/QqUY
David... Are those A/C units under the Garage Windows???  I remember a 21,000 Sf. home I designed for an Indian Family with a racquet-ball court in the basement.. They kept saying: Bigger.. BIGGER!.. Not easy to switch to the limitless budget mindset.. Of course there was a limit when it came to fees..
OK, so I can't leave this BMW symbol alone.
Here I replaced the cardboard cutout 2D trees with a couple
of Frog 3D trees (Sweet Birch I believe they are) and threw in
a stock Chief 3D Backdrop. Starting to get some really nice
interplay between the reflections and shadows.
BMW%20i8%20RT-31-Black-25%20passes-Photo
Check out the Carbon Fiber texture (Patent Pending). I think I
tried about as many settings as Edison tried filaments for his
lite bulb before I stumbled onto this look. I like the way the
"grain" of the weave runs in all the right directions and follows
the contours of the curves.
BMW%20i8%20RT-30-Black-25%20passes-Photo
This is the look that the kids today called "murdered-out"
BMW%20i8%20RT-28-Black-25%20passes-Photo
Personally I prefer something more understated... like this. :)
BMW%20i8%20RT-28-Red-25%20passes-Photon%
Ninety nine and a half won't do.... Got to have 100% Chief
Rich, your experiments are fantastic! 199%. The certified CA.T has gone the 100%, yet can't......
Thanks Yusuf. I'm with you, in believing that Chief has way
more capabilities than the average user is aware of. With
Ray Tracing the problem is the time it takes to explore these
capabilities. I can appreciate that the average Professional
User who is trying to get a design and Con Docs out the door
doesn't have the time to explore all of these possibilities.
But the good news is that I do have the time and will continue
to explore what can be achieved with Chief's tools so that other
users can at least be aware of what results are attainable. :)
Nice work! Did you model that landscape or is it a backdrop?
Thanks Kevin. It's a stock Chief backdrop. The trick is to
get the backdrop and the edge of Chief's terrain to merge
seamlessly. Although the backdrop is titled "grassy", all
the grass in the shots is Chief's stock OOB terrain. I'm a
compulsive tweaker. :) I played with the position and
rotation of all the tree symbols to get the best combination
of cast shadows and view of the background through the
trees. Actually the angle of the sun in the backdrop doesn't
match the angle of Chief's sun in the view but I won't tell
anybody if you won't. ;)
3D model done in Chief, then rendered with affects in Lumion.  The combination of Chief and Lumion is incredible.   All the lanscaping was done in Lumion - adding plans, rocks, mulch beds is a breeze.  Time to get all this done in Lumion was about an hour.
Too bad I don't have Lumion (yet) and too bad I am not immediately up to speed with it! ;)
Mike
Here is a little vignette I created to explore the effects of
using the Compute Caustics option of Photon Mapping.
For far more info than you probably care to see on how I set
up this scene check out this thread in the "Tips and Techniques"
forum
https://chieftalk.chiefarchitect.com/index.php?/topic/10323-exploring-ray-tracing-–-global-illumination-compute-caustics/
Caustics%20On-50%20Passes-44-66-60_zpsqy
The house, landscape, and most of the interior furnishings were modeled in CA.  Some of the 3D assets (ie trees) were found in the sketchup warehouse.
A secret sauce of software was used to bring the model into the publishing platform.
Took a little bit of time to get the presentation behaving the way I wanted, but overall I'm satisfied with the end result.
http://3d.cl3ver.com/xHCB2
Need to market a spec home or design?  Welcome to the future.
Check this out. Here is a "High Definition" close up
taken from my caustics test image. If my math is
correct this image has 16 pixels for every pixel in
the original image.
Original Image: 1600 x 1279 pixels = 2,046,400 total pixels
Close up Image: 6400 x 5116 pixels = 32,742,400 total pixels
          32,742,400/2,046,400 = 16
So what I did was to re-ray trace the original image at the
higher pixel count which produces an image that is
approximately 36" x 28". Then I took the image into PSP
and cropped it down to the close up Image which is a
more manageable 12" x 8".
Running these ray traces is not for the faint of heart. Last
night I started the ray trace with no limit on the number of
passes and went to bed. When I got up 8 hours later and
checked the progress it was on pass 50 something so we
had a little breakfast and let it cook until it reached 60
passes. Total time approximately 8 1/2 hours.
This was so much fun I'm thinking about starting an
enormous ray trace and going on vacation. When I get
back I will either have and amazing image or I will find
my computer in a puddle on the floor. :)
I can envision using this technique in conjunction with
other views. For example you could have an "artsy"
front elevation image done in say watercolor and line
and then have a hi-def insert showing the entry way.
  • 3 weeks later...
I'm always on the lookout for interesting seamless textures.
I found these on the web somewhere and "lifted" several of
them to add to my library. They have a sort of Art Deco(ish),
or is that Art Nouveau(esque) flavor. Here is a little vignette
I threw together using a couple of them for wall covering.
BTW, I forgot that this RT was cooking so this might be a
personal best for me of 275 passes.
Modern%20Chair%20RT-32-275-Retouch_zpsgv
  • 4 weeks later...
