Dongle for X1 needed
BoiseDesigns
Probably best to contact Chief Customer Service and see what they would recommend.  As far as I recall, a dongle is registered to the actual license, so in theory if I sent you mine, you would have to run my license.  And doing so would likely violate the terms of service as my X10 license was upgraded from X1 (through various versions in between) and is the same license.
The dongle will work with any properly licensed software
it is illegal to sell the dongle without selling the license also
CA allows the dongle to be donated to a licensed user
I charged $5 for mailing cost
best to verify with CA if the "borrower" is a licensed user before sending the dongle
Lew
Thanks for that, I have been a licensed user since 2000 but I have taken the last 8 or 9 years off since the crash in construction and I'm just getting back into it.
   I was told by chief architect that I could ask to see if any were available on the forum as they didn't have any to sell me at the time.
 Like I said I'm going to buy the upgrade at the  Holiday sale.
208.944.0777
Unfortunately, I already donated my X1 dongle to someone
hopefully someone can donate theirs to you
be aware that starting with X10 CA no longer uses dongles - software lock only
I have decided to stay with X9 and so has my partner as we prefer hardware locks
We are keeping our SSA active for now so I do have X10
but I have no plans to use it at this time
the timing was unfortunate as X10 introduces the plan set feature and it sounds very useful
but I am retired and for my personal history preservation projects I don't even use anno-sets
so for now X9 meets my needs fine
Lew
I think anything before X6 requires a Full Re-buy now but you are right they do often have 10-20% Off at Xmas.
You can also Rent Monthly now ($199) but it does work out 20% more expensive after the 16 month Rent to Own period
also, if you should decide to buy an older version get X4 or later
as X4 introduced anno-sets
avoid X3 as it had a library subscription system that was horrid
X4 introduced the current library system and is much better
it still needs improvements but it works fairly well
rental would be a good way to go
Lew
