Need help - missing cursor/crosshairs
alheims
A bit frustrated here...
First issue: It doesn't matter what drawing or what size the plan is, I can work away without a problem, but the issue shows up when I open a 3d view and then attempt to close it. I can have multiple 3d views open but if I close them all, my crosshairs disappear from my drawing space. I can move the cursor off the screen to select buttons, but once I place it within the drawing space again, poof, it's gone. If I leave one 3d view open, I can keep working though. So I have to close the plan and reopen, or make sure I leave a 3d view open. This is also apparent within the library 3d views, although that's hit or miss it seems.
Second issue (probably related): I'm working on a window schedule and can zip around in there, UNTIL I attempt to change the label. I click on "Specify Label" but it doesn't change *on screen*. I can type in the box to change it, but can't see what's being typed until after I close the window dbx and open it again.
I'm assuming a graphics card thing, but I don't know for sure. (See attached)
Any suggestions to help alleviate my frustrations would be appreciated. Thanks :)
You show 3 displays: 1 & 2 are driven by the integrated Intel HD Graphics P530 chipset; 3 is driven by the discreet Nvidia Quadro M3000M. I wonder if this may be the source of your issues. I'm guessing you have a mobile workstation and the higher-end Quadro card only has a single port. Maybe unplug the Quadro monitor and see if the problem persists on the Intel displays, or vice-versa.
I just disabled the NVIDIA driver and it fixed the problem, so I updated the NVIDIA driver from the Dell site but nothing changed. I went directly to the NVIDIA site and downloaded the driver and it's fixed.
Thanks, guys! :)
