Elevation Markers for 2nd floor showing up on 1st floor
Mardie
You will need to open each of the affected cameras one at a time and while it is open use the use the Edit Active Camera tool 5b84bddc27cba_EditActiveCameratool.JPG.47ca949c26947339c8cb2e0c519f8276.JPG to access the DBX that is formatted the same as it is for the camera defaults pictured above.
