Do me a favor, import ACAD file and see if to scale
dshall
Thanks guys for the help and thank you Mark for the adjustment.
So weird,  they wanted me to be able to import some of the lines into my drawing.  It was probably done by accident.
Thanks again,  all is well now.
I opened the file in ACAD, and it's pretty messed up. The lot lines are drawn about 5% larger than labeled, but who can trust lot lines? More telling is the graphical scale, which is drawn 4.8368% longer than labeled. The 30' right-of-way centerline measures 29' 8". So, going by the lot lines and the graphical scale, everything needs to shrink; going by the right-of-way, everything needs to grow. Good luck.
