Sign in to follow this
GarageChief
Truss Section
Hi, P L E A S E  need help with Truss Framing with Loft. The loft is continuos in 44ft length, The Trusses are 18ft long from rear gable end.
I am using X10.
Cannot find the answer for trusses in the mid of wider ceiling framing.
CAD settings…Retain wall framing?
Ceiling over 1st floor?
Thanks a bunch,
Marcelo
Top View.pdf
I am using X10.
Thanks a bunch,
Marcelo
Top View.pdf
Hello,
It looks like you have posted a Chief Architect Premier X10 question in the RoomTalk mobile app forum. Please visit https://chieftalk.chiefarchitect.com for further assistance on your inquiry.
    28278
    ChiefPerry
    ChiefPerry
  • Similar Content
    • By HibjurOnline
      Hey All,
      Please help me to create roof over a floor without walls but with only beam/pillars. I want it to be open terrace but covered from above.
      Thanks!
    • By stevenyhof
      Hello,
      I have a soffit that just wants to be angled. I auto created the roofs and this happened. So I deleted that part and made my own - same thing. So I mirrored the rear roof at 45 into place - same thing. I have included the plan - anyone know why this is happening or how to fix it?
      SND1833 Norm Jones Residence.plan
    • By OnlineBuilder2
      Is there a quick way to do this roofline? I tried putting another level above but its not working. I've done this years ago but can't get it now
    • By ChiefuserMathews
      Hello, I am trying to put together a floating deck on top of a roof patio. As soon as I draw the deck it cut a hole in the roof slab. How can I achieve to show the deck?
    • By Designer100
      can anyone explain how and help me enclose between this new gable roof and ceiling. Also looking toward house thru gable closing in with Hardi-siding. The old roof is showing thru and something else when I do a rendering (see attached). Need to look good for a client in 3 D. They are adding a roof over existing 10' x 20' patio.
      thank you if you can help.
      Newell Cheatheam
      CA 12
      newell@newellcheatheam.com
      Patio Remodeling.plan
