Sign in to follow this
TECsta
New layout very slow to respond....
Hi
Recently got the lastest version of room planner. As i always welcome advancements i was keen, however its performance is lagging hard, Takes too many taps to paint and too many attempts to place furniture..
Please advice..
And PLEASE get performance back to the way it was on previous versions, if this is a known issue........
Thx
Can you provide more information on what you mean by "lagging hard"? What is lagging? Placing objects from the library? Moving walls? What type of device are you using?
Can you explain your order of operation when it comes to painting and placing furniture? It would be nice to see exactly how it is taking more taps to complete those tasks.
If there are issues with the latest update, we need as much information as possible to look into how it can be improved.
I get the same thing. I have to try multiple times to change the color of an item. I mean, over and over and over...
Can you explain to me how you are trying to change the color of an item and the issue you are running into?
    28302
    ShanePDX
    ShanePDX
  • Similar Content
    • By CaddCreations
      I recently upgraded to X-9. I'm experiencing (Trump-worthy) HUUUUUUGE lag times when switching from one view window to another. When attempting to switch views by using the drop-down menu under "window" in the main taskbar, in addition to the HUUUUUGE lag time, my aggravation level is further tested by taking me to a view I did not select!!
      Anyone else having the same problem?
      ED
      Cadd Creations
    • By limitless8
      So Chiefers good day/evening!
      Wanted a quick tip from somebody, is there any way that I can make let's say the interior part of a door white, whilst the exterior is dark brown?  The point would be that if it's a door that separates the master bedroom and walk in closet, on the bedroom side it remains white with lites, while on the inside of the walk in, it would be brown?
      I'm pretty sure I remember having done this ages ago but for the life of me can't seem to remember how...(for renderings changing the color on each side each time is an option I know, but wondering what is the actual solution?)
      any and all tips will be appreciated!!
